Title: -Thordarson- woops- I mean UTC S 62 Filament Transformer Post by: WD8BIL on May 15, 2008, 08:16:15 PM I gots a Thor Fil. Xansformer, 105,115VAC primary.... 10Volt secondary.
I would really like to know what the current capability is. Anyone gots the info ?? Title: Re: Thordarson S 62 Filament Transformer Post by: w1vtp on May 15, 2008, 08:53:13 PM I gots a Thor Fil. Xansformer, 105,115VAC primary.... 10Volt secondary. I would really like to know what the current capability is. Anyone gots the info ?? 10 amps @ 3000 vac RMS insulation Title: Re: Thordarson S 62 Filament Transformer Post by: wd5jwy on May 15, 2008, 09:28:04 PM Leeds Radio has a transformer they identify as UTC S-62 10 volt 10 amp filament transformer 3000 volt ins $35.00 - is it a UTC or Thordarson transformer?
http://leedselect.com/parts-transformers.html Title: Re: Thordarson S 62 Filament Transformer Post by: WD8BIL on May 15, 2008, 10:53:14 PM You are abasolutly correct..... it is a UTC.... my bad.
Thanks for the info.... 10 amps will run an 833 filament. Now I'm all set with iron for the big rig. Thanks again. Title: Re: Thordarson S 62 Filament Transformer Post by: w1vtp on May 16, 2008, 11:55:00 AM You are abasolutly correct..... it is a UTC.... my bad. Thanks for the info.... 10 amps will run an 833 filament. Now I'm all set with iron for the big rig. Thanks again. I didn't even notice the reference to Thordarson. The model was obviously UTC. Go for it! !!STRAP!! Al |
