FT-102 Circuit Modifications for High Fidelity AM
(1/1)
Steve - K4HX:
by Bill, W3DUQ
AF Board
Part Number Original Value New Value C02 0.1 uF 33 uF C03 0.001 uF remove C04 10 uF 33 uF C06 0.0022 uF remove C07 1 uF 33 uF C08 1 uF 33 uF C09 10 uF 33 uF C10 4.7 uF 33 uF C17 4.7 uF 33 uF C19 33 uF 100 uF C20 4.7 uF 33 uF C21 4.7 uF 33 uF C76 0.0027 uF remove C116 10 uF 33 uF C124 33 uF 100 uF
Note: If you desire to use the phone patch input for external audio feed, put 220k in series with the center conductor going to the patch input jack and a 1k to ground from the input audio side of the phone patch jack.
Also remove C04 (10 uF) from the AF unit to reduce the overall audio gain. I also changed R11 from 2.2k to 15k to set the gain properly for vox operation.
AM/FM Board
Part Number Original Value New Value C12 10 uF 33 uF C70 0.01 uF 470 pF R03 4.7k Note 1 Note 1: Parallel with 180k to set carrier level for extended positive peak modulation.
Set both tone controls on the AF board to 50%. Frequency response is essentially flat from 40-6khz and down 3db at 16 khz. If you want it flat to 16 khz, just turn up the treble tone control a bit.
There is a problem with the ALC kicking in too early on AM. To fix this, connect a 10k resistor between pins 2 and 3 of P22/J15 on the I-F board. This will raise the point at which the ALC kicks in.
Navigation
[0] Message Index
