A Quick Viking 2 Question
AF9J:
Hi Guys,
I'm looking to remove the last paper caps in my Viking 2. Where C11 & C12 go is a dual capacitor that's only rated at 350V. Only two of the leads are hooked up (in stead of the 4 leads that are on the dual capacitor. So, in effect, only 1 capacitor is hooked up. The schematic calls for 2, 15 microfarad elelctrolytics, rated at 450V. I have 2, 20 microfarad electrolytics rated at 450V. Am I right in assuming that under the 20% tolerance rule, these will work fine for my application?
Ellen - AF9J
Plugging away at work
W1RKW:
Ellen,
20mfd shouldn't be a problem. I doubled that capacitance on my V2 without any issues. There was an increase in the voltage but I would have seen that increase since the old cap was beat anyway and doubling it probably raised the voltage slighty more higher than nominal. I have found new caps to be usually be slightly higher in capacitance than what is stamped on their side but even that isn't doubling the value so you should be AOK.
Jim, W5JO:
Ellen, if you want to be really picky, then Mouser has some 16 Uf axial types you can put in. However the ones you have will work fine.
AF9J:
Thanks Guys,
BTW, I meant C10 & C11.
Ellen - AF9J
n2bc:
Hi Ellen, back in the Viking's day most electrolytics were +100%/-50% tolerance - or even wider! Put 'em in.
Navigation
[0] Message Index
[#] Next page
