DIY Balanced Audio Cable
WA2SQQ:
Start from the end that is secured and keep sliding back. Initially it will start slow, but the more you pull, the faster it advances. Just make sure you have the twisted pair connected to the inner conductor, so you will be pulling it through. I neatly solder the two wires together without twisting them, to avoid any edges that can get hung up on the inner braid.
