Carl....I replaced all the caps EXCEPT the tan postage stamps...My 310 B works well and is very stable...I have also modified it for 160 (easy) Good luck...
I'm pretty much there. The only ones I am not bothering with are the several bath tub caps that are part of the sidetone circuit. I don't see using that so am not concerned.
HUGE difference when I replaced the .02 that went from the power cord to ground. That baby was leaking.
Someone previously added a home brew brute force AC filter wound on two dowels and covered with the old cloth electrical tape. I think I am going to pull it while I am in there as I suspect it was put in for TVI purposes.
I understand 160 is a simple as changing the PA coil to a 160 one and running the bandswitch in the 80 meter position?
Thank for the help Steve!
