March 28, 2024, 12:08:05 PM *
Author Topic: e f johnson coil  (Read 3597 times)
wd0cfc
« on: May 01, 2016, 08:07:58 PM »
Can anyone give me specs on this? What it was used in? Picked it up at a hamfest cheap. Want to use it for base loading coil on a ground mounter vertical. Thanks
« Reply #1 on: May 01, 2016, 08:52:19 PM »
this was most likely used in a commercial broadcast band transmitter ... should perform well in your base loaded vertical if you keep it dry
« Reply #2 on: May 01, 2016, 08:57:54 PM »
Probably 40-50 uHy.   Someone will know exactly what it is,  probably Dennis W7TFO
« Reply #3 on: May 01, 2016, 11:16:29 PM »
That what I used in my vertical loading system:
http://amfone.net/Amforum/index.php?topic=36511.0
« Reply #4 on: May 02, 2016, 10:49:45 AM »
Just guessing at the dimensions I got 46 uh. Here an online calculator you can use. Measure it up and plug in the numbers.
http://www.66pacific.com/calculators/coil_calc.aspx
John K5PRO
« Reply #5 on: May 02, 2016, 08:00:49 PM »
It isn't on this list, having four supports instead of three. If you have a bridge, a grid dipper, a AAD LC meter, or anything, you can measure it. (hint: use a known small value capacitor in parallel and measure the resonant freq and calculate L)
* Johnson inductors list.pdf (262.45 KB - downloaded 144 times.)
n2bc
« Reply #6 on: May 03, 2016, 10:24:30 PM »
Looks like the one in an RCA BTA-1R1 (L302) - 57uH.   I don't have it any more so cannot check the EFJ number, or measurements, etc.
Bill  N2BC
